Regear F350
dzldoctor
Just recently regeared an f350 to 4.30 gears the truck has 37 inch tires. Now the traction control keeps kicking in and the wrench light will come on. Correlation between the output shaft on the trans and the rear diff speed. Programmed the gear change in the abs with the IDS, with no change will the PCm need the gear change also? Truck has mini maxx with gearhead custom tunes. Would the pcm need back to stock then program the gear change in the PCM or will the mini maxx get irritated after the program?
