Remote start shuts off
Bigcountry250
When I use the remote start the truck shuts off after 10-15 min, long before its even warmed up. Is this normal?
Dzchey21
wyoming
Yes the only way to keep it running is do another lock and press the start button twice. That will cycle it again... You can only do that once.
Dzchey21
wyoming
Its some sort of epa regulation from what I understand. Does such you have to baby sit it but 30 min should be plenty long
WHY NOT
Carlyle IL
I wired up the high idle mod to work with the remote start and that helps it warm up quite a bit when it's cold.
It's all about wheel speed and torque.
KCCO
Dzchey21
wyoming
I did one for 6.4s like three years ago. I think it's the same
12v to the pto wire set the park brake and it works. Harness is right under the steering column
WHY NOT
Carlyle IL
Just search for high idle mod in the 6.7 threads. I had to wire an extra switch to get it to work with the remote start instead of wiring it to an upfitter switch.
KCCO
Dzchey21
wyoming
KCCO
Yeah good point because allot of the electronics don't work on remote start
WHY NOT
Carlyle IL
Yeah I just tapped into the fuse I use on my Mini Max which is for the PCM so it is live with the remote start. I will say it works really nice on the cold mornings
