Replaced ipr now miss/shutter.
shorty2tall
Cheyenne, WY
Ok so truck died a couple weeks ago replaced ipr started now between 1500-2500 rpm have a miss/shutter.
Just got these codes 1209, 0603, 1316, 1211, 0541 after removing and reinstalling injector solenoids on drivers side to look at condition.
Here's a vid of what it's doing.
http://youtu.be/naGJhaarjoU
Need help to get my truck back to normal.
Patrick's iPhone5
CSIPSD
Bend, OR
Sounds like an injector issue. I'm not convised its an IDM issue at all.
You for sure have an injector or two dropping, just not sure why. You already told me you checked all the plugs and wire harness...
shorty2tall
Cheyenne, WY
Thanks for all ur help Joe! Gonna try the idm for anyone else who has read this. Did a few tests and that's what it's looking like.
Patrick's iPhone5
shorty2tall
Cheyenne, WY
Replaced the injectors still have the miss anyone have any ideas?
I didn't have the miss till the ipr took a crap and I replaced it could the new one have been bad outta the box?
Or should I replace the ipr and hpop? I can't keep this going. I need to figure something out!
Patrick's iPhone5
rustbucket
Fallon, NV
Could it be air in your system? It took over 80 miles for all the air to come out of my system when i did my injectors.
Bobs 7.3
Plymouth, P.A
Put atleast 50 to 80 miles on the truck at highway speeds and a couple of hard pulls to work all the air out of the system after an injector install.
neverkickn
AR
Air shouldn't cause a constant miss under throttle. I don't think the ipr will either. Sounds like an injector issue.
shorty2tall
Cheyenne, WY
I put plenty of miles on it after the ipr was replaced the injectors and after start up and the idle cleared up got the exact same miss it's a slight miss at idle here and there but very noticeable in between 1500-2000rpm. Harness looks good. And it passed buzz test and cylinder combustion test before replacing injectors but Orings looked bad on a few and all the injectors had 260,xxx+ on them. Engine was rebuilt tho around 200,xxx. DID NOT have the miss till after I replaced the ipr when the truck died.
Could the wire loom got messed up when unplugging everything?
If so where would I find a full loom and harnes for the engine?
Patrick's iPhone5
TARM
Hey guys!!!
What Dave said just to rule that out.
But as well have you bothered to ohm out the wiring harness. When you were in there messing with the IPR and then all the injectors and what not you could have had a rubbed bar wire start to gound out on the VC. As well the UVCH could has something a miss.
TARM
yep had to take the winter off. Bunch of personal stuff I had to address.
