Replacing low pressure turbo oil drain
08strokin
Maryville TN
Hey quys quick question can i just pull the low pressure turbo to replace the oil drain or do i need to pull both turbos?
Tree Trimmer
and put it in the turbo, then put the turbo's in the motor.
if you nick it putting it in that way, it will run down inside the motor. no big deal.
if you put it in the motor first, and nick it, it will run down on the motor, and you have to pull them again
