powerstroked08
Depends on the spring pressure and rpms. You kind of need to know both.
If it is the factory stock motor for it, the castings on the block and heads should be a D7 or a D6. If its aD0,1,2 or a C block your better off because those are a higher nickel content block and are stronger. If the castings on the heads are D0,1, or D2 they are the better flowing heads due to being pre smog motors. C is the 60's designator and D is 70's if you didn't know.Yeah really. Oh well. Bore measured 3.9975 by my mic so looks like it's never been bored before, which is shocking. An original 1977 302.
1978 for the block the D is 1970 the next number 8 is the year in the 70's. So 1978. If you can find some D0ve heads (most guys call them dove heads ) those are a favorite for budget builds. Never mind I'm talking 460 stuff now.
Ghaaaaaa smog motor!!!! Check with the ghetto looking wrecking yards they usually have the old 60s an early 70s heads on a shelf. Or check jegs an summit for a new set of better flowing heads.A little searching with el googleo comes up with a 1978 Lincoln Continental block (D8 is 78 like you mentioned, the V is for Lincoln). As for the head, it's a friggen 85 head.
Do it. Can't make it worse.
I was browsing the Atlanta craigslist yesterday and there were a ton of 302 parts and complete engines/motors. But I don't want to get in that discussion again[emoji23]Yeah I've been keeping my eye out there. That's where I found the truck.
