Reverse Level
3brorce
Looking for pictures of F250s that are reverse leveled and what was taken out of the rear. Currently the truck has factory f250 blocks/springs in the back with a 1 inch spacer under the front suspension. Looking to take the 1" spacer out of the front and make the back level with the front.
ChattyCathy
I have a 12 with stock in the front and 250 block in the back and it is really close to level.
3brorce
My front was about an inch off level before I put the 1" spacer in the front.
3brorce
Who here has cut their front coil spring to lower the truck? How much did you cut?
Dustin did, his handle is Dzchey27
3brorce
Thanks, just threw some diff wheels/tires on and its pretty close to rubbing so not sure if I am going to be able to lower her down haha.
3brorce
Took my 1" spacer out of the front and took the rear overload spring out of the back, pretty darn level to the eye for sure.
swinky
Eastern, Nc
My 03 with stock front, no block rear and removed the thick lower overload
3brorce
Thanks man. If I would of took the 2" block out of the back I would have been bulldogging bad I think.
Jonnydime
Just saw this.
Here is my 350 with 2" PMF traction blocks bottom three springs pulled. I have a load leveling airbag system so it kept things level otherwise with no air it would have been 3" lower. Stock height front springs.
Here is 1 coil cut out of front springs and the bottom two leaves reinstalled minus the fat overload.
If you want I will take a new pic on level ground with polished Welds and factory headlights.
