AirFishAutomotive
Are there many high hp rod failures to speak of ? In the 800+ range? At what point to the stock rods seem to give out?
If you are planning on 900+ and doing a build, id do rods without a doubt, especially since it's gonna be open anyway for pistons I'm sure.
Honestly, anything much over a consistent 1500 ft lbs I would be doing rods. I've replaced a LOT of bent rods in tuner only trucks. Stock compounds make super low rpm torque and a lot of back pressure on a big tune.
You gotta look at torque and where that power comes in.. If you got 1900 foot pounds of torque at 1500 Rpms, think that crank only has 1500 revolutions to create all that torque, hence why stock rods bend and break. I think ryan had a bent rod with his and it was only making 800hp... And people are pushing 1000hp on stock rods (use too) with no bent rods why? Dan had twins which brought on peak power real early in the powerband and caused emence stress on the rods while those pushing 1000hp plus only have a huge single turbo that comes on later in the powerband and rpm range.
