Rosewood's 238/100's
Status
Not open for further replies.
Magnum PD
VA
About 8,000 miles on them, not remans, $1300. Single shots. Need cores. Need bigger for my build.
Diamondtrebel
Do you have any paperwork on these from rosewood?
Magnum PD
VA
I bought them from another member before I got them. It's been a while. I only ran them to start and heat engine up. Jim had them tested before I got them and gave them OK. I can give you my word their ok, but if you want me to see if Jim can pull the history, I can try.
Diamondtrebel
If you could see what Jim can come up with I'm really interested in them
Diamondtrebel
Flow numbers and when they were originally built
V-Ref
9 miles high @ 550 mph
I wish sometimes I had just stuck with 238's/100s and a 38R and called it good when I started my build.
Bump for a trusted member.
backwoodsboy
Merica
If Magnum PD gives you the serial number that Jim etches on the solenoids, you can call him yourself and get this information.
Maybe not a flow sheet but he will tell you when they were built, to what specs, and who originally purchased them.
d7es3l
Colorado
I am torn between 238/100 & 238/200 :( is there THAT big of a difference between them?
ghohouston
Lewisville,Texas
Imo, a 238/100 is the perfect injector. Was for me anyways. Whenever I go bigger on my obs, ill probably go 238-250cc, and PROBABLY 200 percent nozzles
Magnum PD
VA
The bottom pic number is numbered from 100101 to 100108
Status
