Rudy's Diesel Performance's 3rd annual fall dyno day...
Will@Rudy'sDiesel
Burlington, NC
Ok guys I have all the payouts set, for the dyno also 1st place will be $200, 2nd place-$100 and 3rd place will be $50. Now for drag racing. The payouts will be, for the pro street class 1st place-$3,500, 2nd place-$1,000, and 3rd place-$500. For the 7.7 class the payout will be 1st place-$1,000, 2nd place-$400, and 3rd place-$100. The E.T. class will also have payouts starting out for 1st place-$1,000, 2nd place-$400, and 3rd place-$100. And finally the payouts for sled pulling and the classes they are all listed below in the picture. Again if anyone wants any more information give us a call at the shop (919)-383-9300. If you are interested in a booth or banners, let us know before the spots get taken, thanks
Will@Rudy'sDiesel
Burlington, NC
Will@Rudy'sDiesel
Burlington, NC
With those kind of payouts you will get a lot of people racing! I'll be there in the 7.70 class!!
The payouts for the people drag racing are listed above. I will also figure out all the rules for the sled pulling in just a little bit. As soon as I find out something I will post it up for everyone.
TheBigDeOGE
For the 2.5/Hot Street Class the rules can be found at www.carolinapullers.org
which to sum up is Drive shaft loops, stiff knees and weight bar/box allowed. air to air intercoolers. street trucks with licence and the turbo or turbos can be no larger than a 88mm.
Workstock: stock appearing turbo, weightbar/stiff knees allowed. street truck.
2.6 Using TS rules with No protrusion rule on the turbo. (must have fire jacet/helment, trans blanket, air or fuel shutoff and drive shaft loops)
3.0 Also TS rules
Open Class: Run what you brung.
You are allowed to pull 2 times. your 2nd hook has to be in open. no workstock in 2.5 or 2.5 in 2.6 so on so forth. keep any ?'s just PM me.
loboost
If its done you should bring it anyway Lol. TDI what. What car is it?
Sent from on the commode with Tapatalk 2
I plan on it if by chance I get it all together by then. I'll throw it on the trailer...dk if it'll pull the 250 back home when/if I destroy something
loboost
It won't hook. Maybe you've run it before an know otherwise but I think your gonna need some sort of super sticky tire.
You're right. I have run it a few times before teardown this time...and yes its a Spinny lil ***er.
Twisted Excursion
Group rate is set up at Quality Inn 919-382-3388. Name is Rudys Diesel event and rates are 54.99 a night.
