Runs but then dies
60powerplant
Sellersville,PA
I'm working on a 06 truck. It has a new hpop, dummy plugs,ipr,and icp. Truck starts runs drive down the road like 3-5 miles and dies then cranks over for a few seconds starts and dies and try starting agin and fires up. Drive it a mile and dies. It gets a little worst the hotter it gets. I put a air test on it and I can get any leaks. Kid first took it Ford had it on a scanner and said it was hpop but then said it was a ipr. So kid had me replace both. And now it's do the same thing still.
do you have a way to check low pressure oil? maybe the pump is going out?
60powerplant
Sellersville,PA
I had it siting for a few days and I went out to start it and it was die so I jumped it. Let it warm up for 20 mins and drove like 3 miles or so and it die. Then I could get it started because battery's were dead.
60powerplant
Sellersville,PA
The gauge is reading but I guess I should try get a real reading on it. It's also push oil out of the dip stick tube? And it has the ccv runing down under the truck and it's clear not blocked up
Rideracelivemx7
Montana
it pushes oil out the dipstick tube? how much? ive seen a small/very fine mist come out when the dipstick was out and hot. Similar to crank case smoke out of the valve cover, any way you can get a video of exactly what it does?
60powerplant
Sellersville,PA
Yeah if I run it hard for the 3-5 miles that it runs it push oil out all over the under side of the hood. I'll get some pics up. I'll try taking a video of how long it drives for and when it dies.
stupid question but is it way overfull on oil?
