SADP lifter or cam?
JuststrokeIT
About to do a build on my motor as I cracked a piston and am just curious if the SADP lifters are worth it and a fix all for longevity. Or if im better off just getting a cam and mahle lifters that doesn't have such harsh roll over as the factory ones that eat lifters. Any real world input on the life of the SADP ones? This is going in just a street truck that will see towing so not looking at going all out but also don't ever want to have to go back in because something didn't hold up down the road.
StrokiNDieseL
Geneva, Fl.
Contact him, I'm sure he'll work you a deal. I'm running his lifters w/5K miles, 2 dyno runs, running currently @ 700hp ish. Stage1 cam (dnt know manuf) & trucks smooth & quite IMO. I'm sure your other option is ok also, but I heard he's always willing to help. GL
Black AOD
Ohio
I also run these lifters...No Complaints here.
This aftermarket lifter is MUCH better than the stock ones, go look at the comparison if you can find it. Tolerances are much much tighter.
