Scangauge Questions.
jwlandry
S.W. Louisiana
Ive been having my scan gauge for a while now and im really liking it, although I havent really messed with all the functions that it has on it until yesterday.
As I was going through it I realized that this gauge does ALOT more then i though. After going through it I have some questions on some things i couldnt figure out.
The annunicatior....
I know what it is... I think.. But can you set different parameters for each individual thing? Such as:
If boost gets over 28 youll get a light
If Trans temp gets over 200 youll get a light
etc.
Also on the gauge there was a tire size option. I know this wont recalibrate the speedo like i need so what does this do?
For any of you that have a scangauge with an add-on coolant temp sensor, could you post pics of how that hooks into the gauge? Im thinking about adding one to mine.
Thanks.
Tom S
The add on coolant temp sender is not hard. It just plugs into the back with the small pigtail. I did not use the 5v power adapter, I just got 5v off the pedal. I did make sure I had really good connections. I think you can only set the annuciator for one reading if I remember right. I have mine set up for too low of oil pressure with an add on sensor. Aeroforce has some photos on their site.
CGMKCM
Randolph County, NC
I have been looking at scan gauges for the last couple of weeks.
I found that Google searches on Aeroforce scan gauge came up with a ton of info from several different forums. The Dodge truck forums, and some Ford Forums are loaded with Q&A.
I think I read the tire size feature is used to figure out MPG info. It will not do anything to the vehicle odometer by the gauge will compensate.
