Scangauge?
03_PSD
Salado, TX
I got the scangauge from Terminator Engineering and was wondering if I can just hook up the OBDII conection and it will work or will I have to get power from the optional three wire connection? Sorry for the dumb question but I thought I would ask the Army profesionals.
TARM
Could it be that the aux power line kit is for when you hook up the external sensors
03_PSD
Salado, TX
ok, did buzz test last night and it passed. i tried to do the contribution tests and it came up with three codes p0269 no. 3 cyl fault, p0284 no. 8 cyl fault and p0541 manifold heater (mines deleted, might need to put a resistor in there). could this be a faulty cam shaft sensor issue?
Tom S
Motor has to be hot for contribution test. I think 3 and 8 are the grey CPS deal.
03_PSD
Salado, TX
i do have a spare used cps that was good when i swaped in the new one. i swaped it because it was cheap and i was trying to track a problem down and the problem ended up being a loose chip connection.
