Sct 7015 questions
monster14
I'm planning on doing full deletes next week but I got the tuner first so naturally I had to try it out. I installed the stock "performance" tune and i noticed an increase in power which was awesome but I was a little concerned about the tranny shifting violently. When I just mash on the throttle and run it through all gears it shifts smooth but when I would get on it a little on city streets then let off I could actually feel the truck shaking because the tranny was shifting so hard. My first though was that by bringing the rpms up and letting off before the truck had a chance to shift naturally I was throwing the system off. Can anyone give me any insight as to why it's doing this. Much appreciated.
Side note...I haven't tried smoking the tires yet...I'm scared lol
monster14
Crap, my other question was is there a difference in the actual performance tune from PIP compared to the stock sct performance tune or is it the same tune with delete capabilities?
Sorry guys, I'm a total noob :(
WHY NOT
Carlyle IL
Probably need to do a trans re-learn on it. 0-80 at 1/4 throttle then again at 1/2 then again at full throttle should smooth out the ****ting a little bit. Also these transmissions actually learn over time so it will most likely smooth its self out as well.
I don't have an answer about the tunes sorry
dsmracing1
Alberta, Canada
The tranny relearn will definitely give a good head start. I just bought gear head custom tunes since I have heard a Lot of good with them and their transmission tunes helping
With smooth shifting. I'm not Overly impressed with the H&S transmission software. I realize you have the SCT but it could be similar.... Be patient and let it learn for a month. It does Come around over time and get better but I found it still has hiccups...
CoreyMS
You put the "canned" tune in it? I assume you also used the performance trans option. That trans file is a bit rough, the pip stuff is completely different.
bigrpowr
<How I Fly
Administrator
So is the No Limit / Rudy's stuff .
ultra2207
at work
Ok that's what I thought you were saying. I ordered my stuff from rudys which I understand is still punch it performance tunes.
sent via tapatalk
superstroked
Celina, TX
I have am running the tow trans tune with the steet engine tune. So far I like it. I will be deleting soon and will get to try the "custom" tunes. Do the custom tunes make more power than the standard SCT files?
bigrpowr
<How I Fly
Administrator
well the custom tunes are dpf off and the can tunes are dpf on .
colecoop56
Cumming, GA
No the custom tunes are written by a custom tuner and the can dpf on tunes are written by SCT
