BFT
truck started fine with the new set up and now doesnt want to start. went to put in a lower tune and an error message came up. what do i do now?
I did a google search and found this ...
Check engine light on, diagnostic code P2610:
This code for internal computer communications may be set during battery cable service or battery replacement. Disconnecting the batteries or computer will not clear this code. It can only be cleared by removing fuse 36 from the engine compartment fuse box for 30 seconds, then reinstalling it. Then clear pedning codes with a scan tool. Restart the engine and check for the code. If P2610 returns, continue with normal diagnosis. Broacast Message 6954.
