PatriotHauling
The other day my engine died out of the blue. Power still on, but RPMs at 0. I was able to pull out of traffic into a turn lane.
Threw it into neutral and tried again. Cranked and cranked and cranked no problem but no ignition. No smoke out the tail pipe. Quick CPS change and.... Nope. No start. Good fuel pressure (no gauge, just checked flow from the drain valve). WTS light was on when appropriate.
Eventually it started for about one revolution then died. A little while later it fired up and died after about 4 seconds. Then again it fired up and got me about 250 yards down the road before dying again, but this time fired right back up when I put it in neutral and cranked it (while doing about 30mph :joy got another 400 yards and died again. A few tries and it fired up and finally got to my work. Parked it and went to work.
Came back, no start. Fiddled after much reading online and checked IPR and ICP sensors. Both connectors in tact, the IPR had a small amount of oil in the connector. Tried reinserting the IPR connector but the gasket was in the way. Removed the gasket and re-installed the connector and have had no stalls in the last 250 miles or so, but did have one miss earlier today.
My money is on IPR? Thoughts? New IPR or can it be fixed? :shrug:
