seems like it's time for up pipes input please
djberg
so it seems that the common old as soon as you add a fun mod to something something functional breaks... gremlin is having it's way with the truck.
so i got the ficm tuner in last week and the guages. well now i've been progressively loosing boost, jake brake(sct tune add in) has lost stopping power and a very definite change in sound of air leak, along with more a longer smoke clean up time at wot.
at start up idle(only time i really wanna be running my hands around exhaust components feeling for leaks) i cant feel any "drafts" but i can feel it in the butt dyno and above statements are leading me to my best probable cause.
so the question i have is where to go for the up pipes?
rudy's: http://www.ebay.com/itm/HEAVY-DUTY-...uperduty-/400308262701?_trksid=p2054897.l4275
Black Diamond(looks completely identical to the ford factory replacement for an extra $75): http://www.littlepowershop.com/6-0-powerstroke-manifold-to-turbo-y-pipe-drivers-side/
sinister: http://www.mkmcustoms.com/sinisterdiesel60lpowerstrokey-pipes.aspx
ppe(though seems to have the same style bellows as stock): http://www.mkmcustoms.com/ppehighfl...rstroke.aspx?gclid=CP_uqtzkmr0CFYc7Ogod7XUAew
any and all input is greatly appreciated, quality, good flow and economically priced are the goals here. thanks DJ
2wd-fire
I would go with Rudy's up pipes if it was my money. The sinister one will be a bitch to put in with no flex and the egr tube full lenght
djberg
yeah that's a good thought, labled "slip joint" on the sinister wold lead me to believe that they are separable but seems like a good leak spot if so.
strokin6L
Springville NY
A stock set with heavy duty bellows/flex joints will work good. I have a set from MPD that I wrapped with heat wrap.
djberg
hmmm interesting, nice to have a 5% discount as well from here. definitely a new contender. too bad i dont hae access to a good welder for a friend, it would be nice just to buy bellows. but i sure wouldnt trust my abilities for a complete seal.
strokin6L
Springville NY
Here's my MPD Y-pipe with RCD's egr delete pipe...both wrapped.
Strokin89
Manchester Maryland
MPD
2005 F250 6.0 powerstroke, 6 speed manual, egr delete, arp head studs, new oil cooler, aftermarket coolant filter, custom intake, 4" down pipe into dual 6" stacks, 8" lift, TSD super panty dropper tune.
djberg
Ordered, the mpd's today. Hoping to have them by friday, then doing it on Saturday. Along with the regulated return system, so now the next question is can I get the oil cooler out to check the screen while I'm that close without pulling the intake? Since it was loaded with crap when I did the studs, I wanna double check it.
mstng5point0
Salem, Nh
I put Sinister ceramic coated up-pipes in mine. They are a 2 piece set up. I liked the idea of no bellows to fail ever. Install was very easy. I did it when doing studs tho. I also bought an extra set of exhaust manifolds to have ceramic coated too.
