Fordguy100
After a long drive at freeway speeds (over an hour) my excursion has a rough idle. All fluids are fine, temperatures are fine, FICM was just rebuilt by Ed (with proper voltage). Everything appears to be fine, except after a long drive on the freeway.
Basically I will pull off, and the truck will return to an idle. The engine then starts to idle semi-rough. Not enough to catch on an iphone mic, but enough that I can feel it (and see water in water bottles vibrating) and so could my wife. Almost feels like its loping and or it cuts out for 1/1000 of a second every second or something like that. Its not burning coolant, smoking white, etc. On short drives, it does not do this, only after a long drive.
When I get back onto the throttle, its perfectly fine. Acceleration, power, fuel economy, all are fine. Its not enough of a fluxuation to notice any difference on the factory tach, and I didnt change out to notice what it was on the CTS. First thing I'm going to do is to confirm all the wiring to the FICM is attached perfect, although I'm 99.99% sure it is. After that, thats where I need help.
After the last drive, it almost feels like it does it while driving as well. If I hold the throttle to where the rpm's are around 1200 in 1st gear (like 5mph) and I give it enough throttle to maintain rpm's but not enough to accelerate, it seems like it almost does it then as well. Went to the store after the drive, the Ex sat for about 20 minutes. Started up perfect, and ran normal for a couple minutes until the temps got back up to what they were on the freeway (just normal operating temps).
ICP, IPR, EGR perhaps? Wish my CTS could monitor more things.
