Setting timing
Powerstroke Cowboy
Montana
If the timing marks line up it is timed right. Both gears are the same size. So one full turn for one is a full turn for the other. if the marks line up you got it right.
97spoolinstroker
brighton colorado
Well on the book it said to bring it to where the marks are in the center facing each other and have #1 cyl at top dead center and the lifters should be parallel with each other and they werent
Sent from my iPhone using Tapatalk - now Free
Magnum PD
VA
Must have a lifter not going back to home position. See if its stuck.
golfer
both gears are not the same size.
the cam gear is twice the diameter of the crank gear.
one cam revolution=two crank revolutions.
the cam/crank timing marks keep the engine timed mechanically..however the injection 'timing' is variable, and is controlled by the PCM.
Powerstroke Cowboy
Montana
..........Man I feel stupid............
You are right for sure! I forgot and when i saw this i was like you dummy!! referring to me of course. Last cam i did was about 6 month ago. But still... My bad.
Thanks for clearing up this brain fart of mine.
