Several things. Got a new ride!
YJSONLY
Ordered a 2015
F350 Srw CC
Lariat, silver, black interior.
The rear sits higher so a front kit is needed. I know a lot of people are changing out the 250 for 350 blocks in the rear but what front leveling kit is needed for a f350.
After leveling I am sure I will need/want air bags for the loads that I will pull.
Also how do you remove the stickers on the vizors?
Tom@BigTimeKustomz
Bayville, NJ
I did a 2.5" front leveling kit on my '13 and it sits a little nose high now, so 5" rear block kit is on order. I definitely suggest air bags for the rear if you are towing heavy. Let me know if I can help you get any of those parts. Congrats on the new truck!
Sterling6.7
I put a 2.5" on mine. It has the camper package (heavy springs) and it is still about 1/2-3/4" high in the rear. Air bags keep it level. Can't help with the visor stickers, sorry.
YJSONLY
I don't have the camper springs. I was torn on if the ride would suffer to much.
Tom@BigTimeKustomz
Bayville, NJ
I don't have the camper package either. The ride in my truck is better now with Bilsteins on all 4 corners and the larger tires. I'm very pleased with it.
YJSONLY
I have the ranchos on there now. Does changing to bilsteins make it that much better if ride?
Mikeyfitz
Houston, TX
I really don't need a leveling kit if been figuring out. As it only sits .5" lower upfront. I have 2 leveling kits with no reason to use them as my lifts in garage.
Most common is 2.5" though
ftast350
I put on a 2.5" ready lift and 5" rear blocks and it has 1.5" of rake still. I must suggest doing the radius arm drop brackets to keep the steering feeling the same. Mine also has the camper option and all it is is a rear sway bar and overload springs that dont affect the ride, it also has the heavy front suspension so I had to add the 5"rear block.
