IIVonnyII
have shavings in the oil , appear to be bearing material. only have about 10 minutes of run time since the damage happened ( was idle ). shavings only on the outside of the filter, cut it open and couldn't find any on the inside.
is there anything to worry about? its all getting torn down and rebuilt anyways, but in regards to the charger? or hpop? injectors? what gets lubed before and after the bottom end bearings? anybody know?
thanks. hopefully I explained myself well enough
