Short Arm 4-link what's the difference PMF vs RCD?
extreme3807
Bucyrus, OH
Look at post #3 in this thread. That's about how low mine is. No lowering kit. 5.4 coils, 1.5" rear blocks, rear overload springs taken out
Jeff@Spartan
Georgia
They're technically not 5.4 coils. They're just lower weight rated 4wd Super Duty coils. No block and 4800 lb coils is pretty much level and I would consider it a 1/2 drop. With 4400 lb coils and no block, you're looking at a 2/2 drop with a little rake.
onebadf150
New Orleans
Like f150?
I have 5200lb coil in the front which ride way better than the 5600lb that came in my truck. I also have a 1" icon block in the rear which replaced my factory block. At this stance my rear is about .5inch higher than the front. With the factory coils and 1" block my ec/sb was dead level. I going to remove the spring above the fat bottom one to soften the ride in the rear. I also have OUO adj traction bars.
Here's a pic before the 5200lb coils
Layson
As I said earlier in the thread, it rides better, but you can feel the bumps more, kinda a firmer feeling.
How did you get bump steer from that description?
Just kind of a vague description. How does it ride better when you can feel the bumps more, and at the same time have a firmer feeling? Usually 4-links don't have a firmer feeling if you don't upgrade your shocks and sway bar...
I guess the question should be asked if the bumps are felt in the steering wheel or in his seat...
6.4psd916
Roseville , CA
Okay, since it has become a more of a topic of discussion over my "vague" statement. There is no more or even less bump steer than with the factory arms. The truck does sway alittle more if you swerve back and forth but that's to be expected. Steering feels to be more responsive. The firmer feeling I am talking about is mostly when hitting larger pot holes, speed bumps, ect. In general driving the truck rides smoother than with factory arms and shocks. After the 4-link it was better, but once I added the 5100's, it made a huge difference.
Layson
I am sorry but it was a vague statement. This does explain it better, thanks.
Did you have bump steer with the stock radius arms? Typically you don't see that on these trucks.
