Should i get it or wait for something better ? I decided to go with a crew cab...
cagger84
96 f250 4x4 powerstroke turbo diesel
Ccsb
Runs and drives great
Starts great in the cold
No leaks no smoke
240k
Never chipped only 4in exhaust
Everything works as it should
Suspension is tight no shimmies or noises
A lil rusty but super reliable
may trade but make it worth my time
Sent from my LG-LS970 using Tapatalk
Spatel23
Olive Branch, MS
hard to say without seeing the actual condition on exterior and interior
and how much rust does it really have
going off the one picture and description Id say 4k is high
cagger84
There is not to much rust at all and the interior is decent... i was think 3k
Spatel23
Olive Branch, MS
well that's a lot better then I imagined.
If it doesn't have a lot of rust and everything is tight and kosher as he states 4k may not be bad.
3500 and you did good, assuming everything is good to go. (injectors, hpop, turbo)
kramarj
Illinois
That seems like a pretty decent deal. Around here you can't find anything with a 7.3 in decent shape for less than like $5k. I don't think I would hesistate so long as it doen't need a ton of money to put in it.
bucklee00
Check out the upper and lower front leaf spring bushings for excessive wear and the rear leaf hangers and shackles for through hole rust. You may be able to knock him down.
