Side Molding Removal
RNicol
Milford Center, Ohio
I was wondering if anyone had any experience with removing side moldings from the bottom of your trucks. I was wanting to do it to my e99 and I wanted to know the best and cleanest way to do it.
Tncoalroller88
Piney Flats, Tennessee
get u a long piece of fishing line and possibly a heat gun if its not hot outside and get u an edge of it up, then just keep peeling and heating gradually. i think their is a video on youtube of exactly how to do it but cant remember what its called. on mine personally i just got my finders under in and pulled it up slowly
dirtflinger92
Illinois
Does the adhesive on the back of the molding Peel paint or how do you get everything off without Peel off paint?
UtahFord
Bountiful, Utah
At autozone they have a wheel you attach to your drill and it helps remove it without harming the paint
Sent from my PC36100 using Tapatalk 2
David N
Eastern NC
Getting the molding off is the easy part, getting the adhesive is the hard part. I got some DuPont adhesive remover(i think thats what it was called) and used it. It helped tremendously with removing the sticky adhesive.
dustinz85
Houtzdale Pa
3M makes are remover wheel like stated above, you can use your thumb but chances are your skin will be removed with it LOL
