Smoking white
Clouse2411
Bascom, Ohio
A while back my 7.3 pushed the cam gear off and was knocking sensors out. Well I replaced the cam with a colt stage 2 and have a problem. Truck smokes white while in low rpms and also I'm getting terrible injector knock and fuel in my oil. Did injector orings with no change. Sent the injectors out because I had a p0263 and p0266 codes when running a cylinder controbution test. Injectors flowed excellent. Truck ran awesome up the cam gear walking off. Also a light haze of white smoke at idle and smelling raw fuel. Is it a tunning issue? Runs the same just less smoke with the chip off. I'm lost with this.
