So it begins
Magnum PD
VA
I'm use to seeing it come out of the side of the Rez. Your line comes from the back correct?
DocBar
Akron, Ohio
My dad, my buddy Gary and myself fought the intake bridge, new mishimoto intercooler boots and beans plenums for 45 minutes with a heat gun, 3 picks and flat heats to get that damn thing to go on. It kind of bothers me the way it sits and looks but I hope it doesn't blow a boot haha
http://i18.photobucket.com/albums/b145/wtbz400/Mobile Uploads/image_20.jpg
http://i18.photobucket.com/albums/b145/wtbz400/Mobile Uploads/image_19.jpg
http://i18.photobucket.com/albums/b145/wtbz400/Mobile Uploads/image_18.jpg
http://i18.photobucket.com/albums/b145/wtbz400/Mobile Uploads/image_17.jpg
How the hell are you going to plumb that turbo through the IC?
hunterER7
with my continuing research on my up coming build i came across this thread and fell in love. the amount of detail and style alone is mesmerizing. any way as a fellow jersey boy l love to see more 7.3 builds. i was wondering how you made out with all this and if you had any advise for someone who is likely to follow in pursuit.
looking forward to hear an update on this build.
Magnum PD
VA
You can only do internals while rebuilding the engine. Bolt on's can come later. My input.
isootmypants
North Jersey
Exactly. I wish I pulled motor and did rods, girdle, fill, cam and pistons first thing and did injectors and turbo later. You can pretty much drive stock injectors, stock turbo truck on full built bottom end. I'll play with this set up, can go bigger injectors and maybe compounds, and if I really want or get tired of it, drop down to 250/100 and 366. It's always going to be a reliable motor. Don't go hog wild with injectors and turbo if you don't want bottom end to go boom. Yea some people have gotten away with 400/400 and 475 for a while but cringe EVERYTIME in throttle. Or just don't care because they have extra motor and can swap motors out quick. It's pretty much person decision on what you wanna do and plans with it.
isootmypants
North Jersey
Hot side looks completely normal. Coldside clocked a lil odd
Hot side is the red side..... Coming out of the turbo hot.... Cold side is a pipe coming out of intercooler into motor. And does ANYONE understand how a vband works? It's loose to spin it out of the way while working on it right now.
