spacer for dually
Estrogen Hostage
I have a set of 265/75R16 tires that have about 50% left on them and want to wear them out before getting rid of them. By "set" I mean four. They came off my excursion. Anyway, my 235's touch now.
Does anyone remember how thick the hub is right there that centers the wheel? If I take a piece of 5/8" plate and torch out a little hub with bolt holes in it and have it ground smooth, will that center properly of is 1/2" (final thickness) too thick to still center the wheel on that hub?
The truck is a 1994 F350.
Estrogen Hostage
Nope, stock is 215/85R16.
My 235's don't touch enough to cause any issues, no rubbing is apperant, although there is a black ring where they touch when I pull them apart.
lincolnlocker
Central Michigan
Wow! Didnt know they came with that small of a tire. Either way your better off getting machined 1.5-2in spacers and make sure there hubcentric. If not theres a good chance they will break apart.. i have 2.5in spacers on my truck and run 285s and can go as big as 315s if i needed to with plenty of room to spare.
Trapn 6.0
Always on the move!
Bringing this back up. Lincoln do you have any pics? I just put a 2'' spacer on for my 265s and am about to get some 285/75/16s. Just want to see what they look like and if I should go a bit bigger.
lincolnlocker
Central Michigan
Oh got ya.... not yet but I can get some today.... with the 2.5" spacers I have I can still fit my hand/arm between the tires to take the valve stem cap off.... that's how much room there is!
lincolnlocker
Central Michigan
Here ya go..
Trapn 6.0
Always on the move!
thanks for the pics. Think Im going with a 285. Cat thanks for the link already running some nice 2'' spacers. Looks a bit funny with just 265s. lol
Estrogen Hostage
Update: I bought a chassis cab as a parts truck. They have a different backspacing and are factory with 235's. There's an inch between the tires now. Problem solved!!
