uga33
Anyone added the H&S intercooler piping kit with the throttle valve delete to a Spartan tuned truck? Any issues with the tuning and the valve being deleted?
What's the pros to this?
that damn plastic ic pipe breaks, often on long hauls after long duration of heat soak.
Hmm, I must have a ***in unicorn of a truck then. As much and heavy as I tow...never had a issue, 150k hard miles, Spartan tune pushing almost 40 lbs of boost, and still the original turbo.
just one less air flow restriction removed.
Update: Finally got around to installing (ordered the throttle delete kit) the kit today. Easy install. Truck is in limp mode. Got a CEL and she won't make over 13 psi of boost. She is slower to spool also. Gonna work some magic and get it straightened out.
