Speedometer not working
chris1978
Kamloops BC Canada
Hey all
Having an issue with my e99 not displaying any speed on the speedo. Replaced VSS (Old one had a lot of filings on it but tone ring looked okay), ohmed out wiring from VSS to ABS module. No shorts to each other or to ground and no breaks in either wire.
I have speed displayed when I log data on AE and have a P0500 VSS code that keeps returning after I clear it. Had an ABS light on this morning but that was a missing ground under the drivers side battery.
The only thing I havent tried is replacing the ABS module under the battery. Is there anyway to test this without replacing the part?
ithumpwheniwalk
BC Canada
Sorry man, no help here. I've fought this for years in my e99, same symptoms as yours. Finally just gave up and use the gps speedo in Torque Pro. Not terribly accurate, but good enough for me. I never replaced the ABS module under the tray though. That's a thought.
chris1978
Kamloops BC Canada
Odometer work on yours too?
I can see my trip meter counting over tenths when I took it out for a short uninsured trip around the block...
I'll swap the abs module out of the farm truck and see what happens.
Sent from my Pixel XL using Tapatalk
chris1978
Kamloops BC Canada
Check the front ABS sensors.
Only have RABS on this truck. Only the vacuum line and brake line doing to the hubs.
Changed out the RABS module with another unit but unless it's nfg as well, I'm down to replacing the cluster...
ithumpwheniwalk
BC Canada
Nope, odometer does not work.
Arisley
Arlington, Texas
I missed the part about the odometer working. If it is working but the speedo is not, it is the speedometer itself.
chris1978
Kamloops BC Canada
Sold the truck yesterday so it's the new owner's problem now.
Officially out of the 7.3 game now.
