Spit out #7 glow plug---what now?
98stratusryder
Chi-Town
I had the exact thing happen to my truck last month also. Job 2 '08. Had a glow plug code pop up the day prior. Then the following day the glow plug separated and popped out while I was going about 15 mph. Glad it was an easy and cheap fix.
Thats exactly what happened to me, the truck threw up a glowplug code and ten minutes later I heard a compression leak.
white6.4
I have a Question my cousins 08 blew a glow plug out today but it also have a cylinder misfire codes on 1 &2 what would cause this?
forcefed6.4ford
Medicine Hat... Again
Harness or the actual plug?
If it's the harness... High crank case pressure caused by a cracked piston. Tell him to save his pennies. It's going to get spendy.
white6.4
it was the actual glow plug also there was oil on the glow plug. I read on a tread a little bit ago that a bent pushrod or broken lifter could cause oil to get ontop of a piston is this true?
