spool up increase
g2shuck
what will work better divided up pipes or a diverter valve? I have a mock up motor on the way so I can do either
g2shuck
I am currently running a billet wheel ETR HO s472 72/83.90 with race cover 5.5 inch inlet 3.5 inch v band outlet from forced inductions
Purdue_stroker
Ladoga, IN
Spool up was night and day difference before and after I put on my divided up pipes. Definatly a good investment
g2shuck
It was night and dy on a s363? If so I can't imagine the difference it will make on my s472
Purdue_stroker
Ladoga, IN
Oh yeah. Granted before my injectors weren't putting out what they should've been and I had em redone while I was putting the up pipes and manifolds on, but I'm still gonna give the divided pipes alot of credit
TooMuch03
West Bend, WI
I agree with the divided up-pipes, plus, I don't believe there is a diverter that goes from the v-band to a T4, just v-band to T3 or T3 to T4. So, you would have to make or buy up-pipes anyway, might as well just do T4 divided then.
g2shuck
very good point... my mockup motor ships out friday so ill be able to start making the divided pipes soon
g2shuck
I have a lead on a good deal on a diverter valve or a t4 divided housing.... can I run the diverter valve with a TRUE divided up pipe? how would it affect the backpressure on the side that is mostly closed when the diverter valve is closed?
fordfreak4life
Those 2 are not going to play well together, have to gate the Pipe u block off into the downpipe to reduce excess bp
Cutting-Edge Diesel
Newkirk, OK
Don't want to do that. The point of the diverter valve is to divert the exhaust to one side of the divided housing.
g2shuck
anybody want to post up some good rear shots of divided up pipes? I have a good plan but always open to options
FX4 F2-Fifty
East Houston/San Marcos
Thought about that late last night. LOL idea sounded good at first...
