Squeal when cold
strokin20
brownwood, tx
Hey guys, finally picked up a '15 Plati a couple months ago. It's got all the exhaust and intake mods. I've noticed lately upon my first start up of the day or when it has sat for a while, when I move the truck, I get an odd squeal that sounds like its coming from under the truck. I believe it to be drive line related because I can rev the truck up in neutral theres no sound. I don't notice it high speeds, only around 15-20 mph and under. As soon as I stop, the sound stops. I did some searching and found the threads about the transmission squeal, but that seems to only happen during a ****, which isn't the case with mine. It's not a brake pad or rotor kind of squeal either. I'll attempt to get a sound clip but it's not extremely loud either. Just wondering if anyone else has noticed this.
strokin20
brownwood, tx
And just in case anybody was wondering what said truck looks like, I'll throw a few pictures up to show off the new shoes.
Sent from my SAMSUNG-SM-G870A using Xparent BlueTapatalk 2
78f100
Bonifay FL
Does it have a egr delete? If so make sure it's not leaking exhaust at the block off plate. Sometimes a slight leak will squeal but will stop when the engine warms the leak stops.
strokin20
brownwood, tx
Hmm, it has the block off plates. I'll def give that a look, thanks for the heads up.
strokin20
brownwood, tx
Checked the egr plates and no leaking there. Guess I just need to get it on a lift and inspect the driveline.
