Tom S
- Joined
- May 20, 2011
- Messages
- 3,365
- Reaction score
- 1
I am glad you posted like you did, very squared away. If I missed it sorry but how many miles now on it?
Soldiers running the SRP1, report!
During a "full power" run....answer the following first, then post up your comments.....
Date of purchase- February 2011
Miles/races/pulls on the pump- 3,000 miles and 10 or so 1/4mile passes
Max duty cycle- I only checked 1 time and it was 38%
ICP- 2900+
Injs capacity/nozzles- 250/200's
Leaks associated with the HPOP? None
Running a HPOP res supplemental feed line? No
Are you wanting for another/different HPOP? If so why? NO
Driving impressions? AWESOME! Much more responsive. The startup time never changed for me but I have personally installed and started 2 others on stock sticks that the cranking time was greatly reduced.
If you've got a track time, dyno number, or sled pulling accomplishment with the SRP1, post it.
Purpose of this thread is
1. A place for folks running the pump to post their setup, and how it's supporting it.
2. A place for folks looking at a HPOP for their truck to see what the SRP1 can and can't do.
No fanboy, HPOP war BS....just post your truck that's running the SRP1 and move on! We're lucky to have as many good HPOP systems to choose from IMO....thanks to all the folks that put many a hour of effort/homework into making them happen. Like TOM S posted below...lets keep the discussion oriented towards the SRP1 only...not a SRP1 vs. Duals vs BTS vs Gen 3 vs Billet Stealth vs whatever...... they're all good pumps! :fordoval:
It was spurred on by Tom S's post here...
Date of purchase-purchased 3-11-11, received and installed 5-28-11
Miles/races/pulls on the pump-7-8k no races yet
Max duty cycle-Haven't had a chance to scan it, having injector issues.
ICP-
Injs capacity/nozzles-Stock, soon to be stage 1s
Running a HPOP res supplemental feed line? Yes/No No
Are you wanting for another/different HPOP? If so why? Nope
Driving impressions? Smoothed out idle, Truck has 267k on it with original hpop until srp1 install, much more power and quicker starts. It pulls much harder through the middle of the rpm range. I can't wait to get the new sticks in and some issues ironed out so I can really get into it
Im having issues with my pump after it warms up, its making the truck idle kinda shaky and its driving me nuts, but it sure does put out the oil. Ill post up some specs when i plug in ae. But does anyone have an idea of what it might be, i had my chip reburned, and a new ipr and it still feels funky when warm. I dont mean to derail the thread, but after this pump it hasnt idled the same at all.
Driving impressions? Hot Idle issue as mentioned earlier, a touchy pedal @ light cruise, with 330k on the clock I have not ruled out low compression yet , although I do feel it's tuning related ,may try the IPR harness and see what happens.
So does anyone have these pumps in stock right now ready to sell? I am guessing not.
ICP-
Well to continue on my review I have been having a hot start issue since the pump was installed, we have tried everything we could to fix it but to no avail. Pump is going back to Gary this week to have it looked at. Apparently I have the second bad pump ever, considering how many there are that's not bad at all! Hopefully he can get it fixed up real quick, my pickup runs great, you just can't shut the dang thing off cause it wont start again until its cooled down. I'll update when it gets figured out.
Sent from my DROIDX using Tapatalk
Good stuff, and thanks for sharing. This is the kind of content I was hoping for this thread...folks posting up the real deal on their experience with this pump....good and the occasional potentially not so good (as with all performance products) whoever the vendor/builder of them is.
Be sure to post up the update...it doesn't have to be good news either.
Here's to hoping it is though :toast:
Why do you say the second bad pump ever? I have heard of a few that had issues but still a pretty small percentage.
Jake said it was the second pump that had to be returned. I may have misunderstood what was said but in any case there haven't been many and it'll hopefully be fixed before scheids. I'll get some real data during that trip to post up. Going to have a new scanner by then and lots of miles towing vanderchevy18 out there.
That could be helpful for others than may have a similar issue possibly with any hpop pump.
Have you contacted Gary yet about this issue?
