Stay of execution.
JoeDaddy
Gridley Ks
If you are still going to go the radius arm route you need to change your design a little bit..... you need some sort of bushing for flex at the axle end.... otherwise you've just built yourself a very rigid swing arm at the front of your truck.... I assume you know this, but others might not.
Right. That's part of the reason for swapping the entire chassis to a 4wd instead of a 2wd conversion. The length of the swing arms would allowed plenty of rotation but like I said in the last post....no need to reinvent the wheel.
On edit: Plenty of rotation meaning for hauling on hwy with some field work. 6" of articulation being plenty.
JoeDaddy
Gridley Ks
are you going to fish plate it? looks good
do you have your flame suit on? :)
Yup and it will go down the road with a 20,000 lb gooseneck just like it is :D
Good job Joe, glad to see it moving right along.
If I might make a suggestion, I would have cut that frame in a Z & then rewelded it.
Something like this-
Its sort of a rub Cat. Strength is for the most part reliant upon the Fitter and not the fit.
duke1n
You have that case of beer you owe me? Is JoeDaddy a welsh that is not to be trusted to pay off his bets?
duke1n
Maybe I wasn't clear? Maybe you struggle with reading comprehension? Whatever it is are you going to put some money behind that mouth Dorthy?
A beer is enough, throwing C-notes around doesn't make my best guess any more accurate than your's. :toast:
Sounds like a bet to me? I figured people on this forum that made bets would stand behind their word and pay them off. Am I wrong?
Here's the thread and JoeDaddy making the wager. Are you going to say this was not a bet?
http://powerstrokearmy.com/forums/showthread.php?t=14857&page=5
JoeDaddy
Gridley Ks
JoeDaddy
Gridley Ks
It's been well over a year mow pulling heavy loads both GN and BP. I think it's safe to say it's tested.
A lot has changed recently, I now have 2 SD's to do the pulling. The OBS is about to go to pasture. I can't convince myself to sell it and it's only worth anything to me. So that leaves 2 choices. Restore it or Race it. :D
I'm currently sitting on 5 sets of spare injectors and HPOP's so I should be able to secure a good set of injectors and pump. Turbo would have to stay stock for now. Maybe this time next year I can find a BTS and go balls out!
bluedge8
Champlin MN
Your alive LOL
I was looking for an sd for side work duty but couldn't justify the cost. Ended up buying a 2001 gmc Yukon xl with a 5.3,,, Still have my '96 though
JoeDaddy
Gridley Ks
Decisions.....Decisions.......
300/200's or a more pedestrian 250/100?
Either way I'm going to need a tranny and turbo(s).
