All I have is for the rebuild kit. (bearings)
Part number for the kit: F6AZ-3605-AA
It will come up as a Ford Freestar, or something like that, mini van column rebuild kit. Idk why just does.
Kit includes:
-Steel tolerence ring
-Steel sleeve
-Bearing pre-load spring
-Upper bearing snapring
-New steering wheel attaching bolt
-Small upper bearing
-Large upper bearing
-****ty instructions
Fairely easy to do. Simple hand tools. Just remember the way you take apart all the plastic peices to the internal ignition parts after removing the actual ignition with the key. Some steering wheels will require a puller, mine did. Others will not. Ive heard both. If the shaft is tore up at all from the destroyed bearings you will most likey need to replace the shaft. (upper) I made the mistake of cleaning up the tore up shaft and installing the new bearings on it. (being cheap) And I have a squeek in the wheel again. No play just noise, for now. Mine was so bad before the new bearings the wheel would bind up mid turn and not move. Fairly scary on the street. LOL
