Still leaking oil.....
canelane
Albuquerque, NM
According to 2 mechanics the hpop was bad. I just finished installing a T500. Started the truck and let it idle for about 5 minutes while I looked for leaks. No leaks. I drove around the block and looked again. I have oil on the motor right behind the hpop. I dont see where it is coming from. Any ideas?
DEEZUZ
NO PUKESTERS
NWI
Yea.. park on ramps and spray the piss out of it... that way everything will drain out back... than drop inspection shield on trans so no further residual messes you up.
TARM
A friend was just talking about that and said that is the key inspection point to check if someone says they keep there engine clean. A finger down there tells the tale LOL
TARM
Oh man did we just jump back to high school. LOL I figured someone was going to run with that one once I re read it.
