Stock .84 Housing Modification
JAP
Diamondhead,MS
Could a mod change the title? It was supposed to say *Stock
Just wanted to share these pictures. It's rough and I need to clean up the wastegate hole.
I don't have any numbers or impressions from this, but it seems like there's no way that it couldn't help. I think it'll be a great mod to do for the guys that are running the batmowheels and trying to make the stock turbo live with extra fuel.
JAP
Diamondhead,MS
I opened up the flapper hole a little, but I needed some bigger drill bits. I'm going to bring it to work and clean it up and drill the hole a little larger.
PStroked444
OR
I guess the question would be did it make any difference?? How much of an improvement did it make? any dyno? Just asking I am not passing judgement. I have wanted to do that a while back to help relieve some BP on the top end with the stock housing.
Thanks....:D
JAP
Diamondhead,MS
You should do it! I have a TN Knock-off now that seems to work great, so I'm not all that anxious to try this stuff... That being said, I may just swap it on to give everyone my impression. I know that I do miss the response of my stock turbo.
It's definitely going to make an improvement for those running larger than stock injectors and even really aggressive tuning... I think that is a no-brainer...
The pressure difference between the passenger and driver sides of the motor has got to be pretty extreme once the wastegate does start opening.
907DAVE
AK
Might give this a try when I swap motors between trucks, but my stocker seems to be working pretty so far.
PStroked444
OR
If I was not using my truck every day I think I might try it. But who knows. Keep me posted if you actualy get the chance to do the .84 mod. Good luck!!:gun::rockon:
JAP
Diamondhead,MS
I was able to open it up all a little more at work yesterday...
Took a drill press and drilled the divider some more, and then cleaned it up and "sharpened" it a little...
Then I opened up the wastegate hole to 7/8's... That's as large as you can go without the flapper getting in the way... Mine got a little scarred but I cleaned it up and it's fine...
Then I ported the hole with my Dremel and made it taper up to the flapper.
And there is the backside of the hole...
RedSmokey
Sacramento, CA
Might do this for chits and giggles till I throw the van turbo on. I would guess my wastegate is open probably more than 50% of the time i'm driving LOL
JAP
Diamondhead,MS
I honestly think that this will make for a better turbo than a 1.0 housing stock turbo... But that's just me. Once I get it on I'll know. But to me, it seems like I can have the best of both worlds... Neck-snapping spool-up as well as good top end, and that will be achieved by adjusting my wastegate spring tension and using either a boost or backpressure referance to open the actuator.
JAP
Diamondhead,MS
I think I should have one laying around, but I'll keep you in mind! Thanks! I only need the little piece that goes from the turbo inlet to the CCV piece.
Homesteader
JAP.
How's it working out? I'm running a stock turbo for now. Might just do the same if it works.
