Jesse_01
Does anyone make stock height dual rate/progressive coil? I don't want a leveling kit due to the fact I only run a 33" tire.
Sent from my SM-N900W8 using Tapatalk
Yeah thats what I have come up with. The aftermarket guys say a stock height progressive/dual rate coil would bottom out.I don't think anyone does. I've search alot in the passed and all I can find is people using softer ford springs.
Any idea what stock ford coils guys run? Are they the f250 gas truck ones?
Your spring will only ride so well. Change your shocks if you haven't.
What part number is the 4400 coils? Did the truck ever bottom out? Wonder if there are 4600 coils. Just a 1" drop.they are 4800 pound coil springs will ride a decent amount better. I have 4400lb coil springs in my truck right now and I'm switching to carli 2.5" leveling coils and 35's right now i'm on street tires which measure 33" my reason for switching is hopefully a better ride, even though it rides much better on the 4400lb springs its lowered about 2" and 35's won't fit especially with -25 offset and no one makes a stock height progressive rate coil spring so carli was my choice for ride quality.
My truck has a snowplow/camper package so its stiff in the front.
The 4800 would probably only drop 1" or so.
Okay. I will see if I can find some at the wreckers.probably. I run 33's right now with my 4400 coils fine. still plenty of room, they do rub on the inner fender liner but i could easily zip tie it back if it bothered me.
