Stock Hpop #'s
Justin@DP-Tuner
That can vary greatly depending on the tune. Ideally, you want to see over 2600psi with a duty cycle below 50%, but with hotter tunes it is harder to see those kind of numbers, especially with a stock HPOP.
With a stock tune, you should be able to hold 2800-3000psi with a duty cycle below 50% as well.
mandkole
Northwest
^^^ agreed.. Guys with similar stuff (stock pump/split injectors) have reported 22-2300 on high PW files.
Carolina444
Dallas ga
Ok.. Well it seems like it's well bellow 2600 and higher than 50%.. I will go through all the saved data tomorrow and post it. Thanks for the info
bruce
Middle east
With a 15* and ab's on a 100 hp tune it's prolly gonna be workin it's ass off. Icp is gonna drop prolly 2400 or below and duty cycle will be 60%
Carolina444
Dallas ga
Forgot to post some numbers.. I didn't have much time to log today but here's one that looks bad in my opinion.. i was seeing 2300-2600 at WOT with cold oil (110*) is this pump bad?
178* oil temp
73% throttle
70% duty
1743psi
bruce
Middle east
Those numbers are pretty bad, could be injector o-rings, worn injectors, oil rail plug o-rings, but being a 15 degree with quite a few miles its probably a tired hpop.
Carolina444
Dallas ga
I've only had the truck 1.5yrs so I have no clue if the injectors and Hpop or originals at 257k.. I did replace the inj orings last winter. Truck seems to run ok
Justin@DP-Tuner
It's likely a mix between worn split shot injectors, a 15* pump, and a hotter tune. Those three things make for a bad combo when it comes to ICP.
mandkole
Northwest
^^ agree
Yeah, that pump is likely the original. A new pump would be worthwhile to get the most from the new injs and turbo.
Carolina444
Dallas ga
Called dyno proven back to see what kind of price I could get since I ordered pump and lines earlier today. Jonathan gave me a great deal on some 230/100 and took his time to discuss my options on my build. Looking forward to buying more from these guys soon
