Stock rebuild ?'s
blk99
So i am thinking I wanna save $$ do rebuild my motor this winter but, honestly, i dont have a clue what it might cost....
motor has 308k on it and that rises by about 1k a week...
I am thinking i want just a stock type rebuild as i dont forsee going any bigger with mods....
I reckon machining is the big variable but what all do i need prices on, heads and bores, or?
Any info is much appreciated!
CSIPSD
Bend, OR
Seriously???
Your even slightly thinking about this, after helping me swap motors 2 times...
Find a low mile take out, swap it and move on.
The last motor I got for free, the one before that I was only in $400...
Otherwise the rebuild kits are $1000 or so, machining will run you $400-$700 for block and heads...
Seriously???
agree with joe 100%! I went the rebuild route and with some of the upgraded parts I spent a hefty amount on it when it was all said and done.. if you are staying near stock power levels then find a low mileage motor and swap it over..
blk99
If i got lucky enough to find a motor like your last one, i would be all about it...
Powerstroke Man 6.4
Seriously???
I agree with Joe 100%. Unless you are going bigger with mods later on just stick with a lower mile takeout.
I had 360K on my L 99 160/100's. Stock/original engine everything other than the injectors and HPOP ran 3500 + RPM everyday towed my trailer almost everyday and its still going strong. It also had very little blowby.
blk99
My last pickup had 499k on the original motor the day i got rid of it and it was tighter than this motor.....
