Cheap6.7
Anyone running a 64mm VGT style on stock 11-14 fuel? If so, hows it drive?
Thanks
Thanks
I'm running the 64 street max on stock 14 pump. It's drives ok. I'm lifted on 37's so it makes it a bit laggy but not terrible. I think it's all in the tuning honestly.
I'll have dyno numbers this weekend to show gains with just a turbo swap. A billet 61 was good for 75rwhp over the factory 11-14 turbo all things the same. I'm not sure anyone has dyno'd just a stock 15 turbo swap.
With the right tuning, the StreetMax spools very well. There's obviously a little more lag than the stock 2011-2014 turbo, but it's not bad by any means. The StreetMax is very drivable, and the mid-range to top-end power is fantastic. I've tried a couple different tunes with mine, and the right tuning really makes or breaks the performance and response.
Dzchey21 made 559@4000 ft with a 64mm StreetMax on a stock pump..... He also has one of our stroker pumps to test....
