stuff for sale
swamp_ratt
hudson, wi
7.3 block
Forged rods
Heads (complete with valve train)
Obs accessory brackets
Oil cooler
Crank
Pan
Stock intake y
Stock pushrods
Stock head bolts
Motor mounts
Obs engine harness
1995 manual trans pcm $100
Make offer on above
Also have Garrett GTA4202 turbo with 1.44 housing, original Garrett compressor cover and NTPA Certified compressor cover. 1200 firm (not motivated to sell.) Has 3 hooks on a JD Super Farm
If i think of anything else ill add it. Need it gone asap. If all else sells i will keep the turbo for my CR!
text 651.263.1497 for pics
swamp_ratt
hudson, wi
Also i can get the crank coated in oil shed and milled for better balance (keep critical mass toward center of crank more) as well as have the heads ported fairly cheap
BBottoms
Buffalo, KY
Is the engine harness in good shape as far as plugs/connectors/etc? Also interested in the power steering/vacuum pump accessory bracket.
swamp_ratt
hudson, wi
I do believe the harness had a couple plugs with broken clips, but i will look when i get home. The bracket is all yours though. Do you want the steering pump with it? I do not have the vacuum pump anymore. It was brand new and traded that and the fuel bowl and fuel pump for a 6.0 IC
swamp_ratt
hudson, wi
Bbottoms... The engine harness has one brocken clip on one of the vcg plug ins and a fuel bowl plug has a goofy wire but otherwis good
swamp_ratt
hudson, wi
Bump, still have stuff that has to go
3 icp's
1 black cps
Forged rods
Oil cooler
Intake y
Head bolts
Pushrods
Pcm
Motor mounts
Make offer, need it all gone. Taking up needed space
swamp_ratt
hudson, wi
NEEDS TO ALL GO NOW!! Some chit came up in the family where i need to unload everything yesterday! Make offers
