Sump Special
Jeremy@dynoproven
Chattanooga, TN
We are running a special on our remaining inventory of fuel sumps. They're all black anodized finish (i might have a few raw aluminum ones left)
We are selling these for $100 with free shipping for forum members while supplies last. Send me or Jason a message or call the shop to order.
(706) 841-2496
We offer optional outlet fittings in
-6 AN, -8, AN and -8 pushlock.
thuglike
Linden, NJ
If I'm not mistaken there is only 1 spot on the tank any sump can be installed.
The flat spot in the middle (pretty much directly below the factory pick up)
In any case, you need at least a 3" area. That's what you drill with a hole saw.
Jeremy@dynoproven
Chattanooga, TN
(706) 841-2496
Also I am out of -8 pushlock fittings now. I can either send it with an AN fitting or without a fitting. The sump takes a 3/8 npt fitting.
Strokersace
Towanda, KS
You just need a 3" hole saw, so you basically need a 4" diameter, but I would suggest finding the lowest possible point.
I'd be installing on an OBS rear tank. The only flat spot on the bottom is approx. 4". I'll have to measure to be sure.
Also, the npt is 3/8" and not 1/2"?
Jeremy@dynoproven
Chattanooga, TN
Yes, 1/2 npt would be way too large. NPT sizes are a lot larger than regular
tap sizes. We use 3/8NPT because it is a common pipe tap size for a variety
of different outlet fittings.
Magnum PD
VA
Is it stupid idea to use the OBS selector valve for DD to use both tanks then T in a line with valves to a sump for high fuel needs?
CSIPSD
Bend, OR
If I were to do a performance fuel system in an OBS, the fuel selector valve would go byby... Two sumps, one double tapped just like all the semi trucks I have ever driven...
CSIPSD
Bend, OR
I have my 110 gal tank gravity feeding my main tank... no overflow...
Sent from my DROID RAZR using Tapatalk
3/8npt is only 1/4" I nside diameter..... if its a machined part, why not just make it at least 8an if not 10an? And if it needs to be npt make it 1/2 npt? Shouldnt be any different to drill and tap 1/2npt then 3/8npt.
Yep, been done for many many years.. easy peasy
HOOV3R
Central PA
What? 3/8s NPT has a 3/8 ID. 3/8s NPT is comparable to -8.
SCRATCH ALL THAT
Your right.. I had a brain fart. I was thinking hose barb.. 3/8 hose barb are only 1/4" inside and 1/2" hose barb is 3/8 inside... carry on. Dont mind me in the corner with the dunce cap on!
