Superduty 7.3 Valve covers.
Wackerjr
Looking for a cheap set of Superduty valve covers... Engine I have has OBS ones on it... Thanks...
MossBack
UTAH
The obs and SD valve covers are exactly the same. The fill neck is the only difference. I have a set that I'd send ya for $60 plus the ride and I will give the fill neck and ccv doghouse for you.
Wackerjr
No sir... they are not :)
Superduty will have an indent on the area where the Harness goes through the cover in the center...
OBS has them front and rear for the same respective item :)
Hoping to find a decent non-bent set... I might have them Chromed :)
Cr500
And if it matters 94.5-95 are made froma single stamping, 96-03 are 2 pieces stamped together. It was for noise.
MossBack
UTAH
Right I see now my bad. Always learn something new .
davey99ps
Waterford WI
I never knew about the differences other than the filler neck. I have a 95, would swapping to the newer style actually make a noticeable difference in sound? Also, if I keep my original valve covers, can I add the filler neck from an SD to my covers? That's been on my to-do list for awhile now, I just haven't ran across anyone getting rid of a filler neck
dentexpowerstroke
denton, tx
I have an extra set. I had the set that are currently on my motor rhino lined and that made a difference in sound. Pm me and we can work something out.
Wackerjr
There is Really NO other difference other than already stated....
Sound levels will not change EARLY 94-95 trucks had single stamped
The filler neck will fit ANY year cover....
OH and PM sent.
TRUBBS
Balls Deep
best thing for sound is to put a thick coating of bed linner (rihno linning, line-x ect...)
it helped alot on my old '99 i did the oil pan and valve cover
