swaybar endlink replacement bushings
fiveohpatrol
Hey guys,
I see that Energy Suspension makes a complete sway bar bushing kit for the superduty pickups, but they don't list one for the Excursion.
I did find the part number for the sway bar frame bushings, but no endlink p/n.
Is the endlink bushing the same as the truck? If so, I can just buy them separately and get the proper 36mm frame bushing.
Just want to make sure I get the right parts so I don't realize I have the wrong ones when it's all apart!
thanks!
norcaldiesel
The end link bushings are the same as the Superdutys, while the end links themselves are different lengths based on vehicle height.
A while back I bought a complete bushing set from Energy Suspension. I bought the Graphite impregnated Poly bushings, they're black instead of Red.. I know red looks better, but it is also apt to get noisier if the lube wears off so get the graphite impregnated ones.
You should be able to press out and press in the end link bushings by using a vise.
