josh@thedieselcartel
Ok, the jealousy is setting in.
Your not done yet?
That's not adjustable beyond pinion angle and a couple of other small things after it's welded in. It's considered non-adjustable.
This is an adjustable 4-link...you can move the bars to fully dial in the rear suspension. This is what you want on a drag car.
It still needs to be measured out and set up correctly or you can do more harm than good.
read this...it's a pretty simple explanation.
http://www.how-to-build-hotrods.com/tuning-4-link.html
Never hurts to mention it....you haven't said it was being built elsewhere. And that's a hot rod shop....so hopefully it'll be close enough for drag racing. Others may be wanting to mimic your build and may not know the difference...we're here to share info, right?
The cars I used to crew on and very occasionally still do were built by Bickel and Haas respectively....I know a thing or 2 about setting up a 4 link. If you don't want me to share just say so....
Your not done yet?
With the extra work and mess of pulling the cab it didn't seem necessary. We don't have a AC capture machine either.
Really wasn't to bad with the cab on so far.
The kit is from H&S. Dual fueler. Turbo kit and low pressure fuel.
