Third gen Cummins injector swap
Jake
TEXAS
Does anybody in North Texas have the tools? Ae for the Cummins? I'm going to help a buddy with it. The install does not seem tough at all, just have not done it on one of them.
Sent from my DROID RAZR using Tapatalk 2
Trapper
Surprise AZ
It's easy just be careful with the wire nuts on topic the injectors. There freaking tight. Then don't over tighten then they will snap.
Jake
TEXAS
What about the tools to get the tubes in and out? Getting the injector out of the hole does not seem too bad without the tool. I have two to change here in the next couple weeks. He needs to get it plugged into the scanner again though he does not remember which injectors they were. I only have the ford package for AE
THANKS!!!
jkidd_39
NW Arkansas
IM driving ATM but ill get you a link for the injector tube puller this evening. Its like $8
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
fordfreak4life
THANKS!!!
Take the injector lines off, unscrew the nut, pull the tube and pop the injector out
Sent from my Milestone X2 using Tapatalk 2
Jake
TEXAS
I just don't want till f nothing up! I can't believe they don't have hydraulic lifters!!
Deputydog
Spokane, Washington
Cummins injectors are about the easiest ones to replace. No special tool needed. Just unscrew the hold down nut on the tubes and they pop out. I would suggest replacing the tubes but if you don't, look the tip of the tube over closely.
Mike@MPD
Pasadena,MD
What year is the truck because in the 6.7 s you have to put the injectors in the same spots they came out of because they are programmed to each cylinder
Sent by my Nexus powered by this (╯°□°)╯
Jake
TEXAS
It's a 5.9 3rd Gen I think it's an 05
