Thoughts about this 3" spacer lift?
Platinumf250
Dfw tx
Found this kit used for $200. Pulled off to go to a 6" lift. Thought about picking it up, doing a 4" block and new u bolts and running it. Or could I use 2.5" icon coils and maybe a 1"-1.5" spacer with it? Want it to sit level or maybe 1" higher in the front. Don't want any rake. I'll upgrade to some fox shocks if I decide I'm happy with the height.
Same kit as this link:
http://www.rockymountainsusp.com/li...0/2011-15-v10-diesel/561-20-hk.html?c=288&i=1
TripleE44
Keller, TX
The icon coils with a spacer is going to ride much nicer. They don't call it rough country because it rides good. That height is what I have with a 4'' block. If you measure it on a dead level surface, the front wheel well is an inch taller than the rear, but it doesn't look like it leans backwards.
UNBROKEN
2.5" spacer and 4" block sits dead level on mine. You're gonna want a trac-bar drop bracket to center the axle as well.
Platinumf250
Dfw tx
It's just a 3" spacer with some rough country shocks so I don't expect it to ride great, but figured since I'm using the stock coils it's be about the same. Getting the kit for $150 so I just wanted to make sure it would still work with the icon coils and 1.5" spacer. Don't know how much lift I can get out of the drop brackets it comes with. I'll probably order a set of icon coils to go with it.
TripleE44 your truck looks good man. I live in krum, just north of Denton. See your from Keller.
Thanks unbroken I'll pick one up.
Nj67
South NJ
+3 readylift sst
I added some fox 2.0s and a bds dual stab with fox 2.0s
Sent from my SPH-L720 using Tapatalk
charles henson
+4 readylift sst stage 4,also with fox 2.0's and dual fox ss,rides slightly better then factory but looks so much better!
Platinumf250
Dfw tx
I went ahead and bought this kit. It's missing the two bolts to hold the spacers down. Anyone happen to know what size and thread they are? What's the max height I run with these drop down brackets and track bar brackets it comes with?
The ready lift is almost the same price as a full suspension lift.
charles henson
Got my readylift stage 4 for around $525 threw autoanything after a 22% discount & $100 mail in rebate.
You just have to shop around & don't be so froggy as eventually they'll send you a special sale offer & when i seen it also qualified for the $100 rebate i jumped on it.I also got a trifold tonneau threw them delivered for just over $200,good luck hope it works out for ya.I also got 4 fox 2.0's for $415.
Platinumf250
Dfw tx
Doesn't sound like a bad deal at all. If I found one for that cheap I'd probably buy it too, especially the fox shocks.
Anyone know what size and thread bolts I'll need for the spacers?
Southern Illinois
Another vote for 3 1/2" Ready Lift kit
I put on my 12 with 1000 miles and have 35k now and not one issue. Rides exactly like stock, doesn't replace shocks just spaces and handles great do to parts to drop front driveline to match factory angles. Didn't want to jack up ride on new truck and it sure didn't
lincolnlocker
Central Michigan
i have been to krum before.. lol.. i have a aunt and uncle near Era!
live life full throttle
Platinumf250
Dfw tx
Already bought the rough country lift.
Small world man. My moms side of the family is from michigan actually, Adrian area.
Anyone know about the bolts?
charles henson
Definitely check them out,once your a customer & sign up for the email offers they'll offer some very very good discounts & that's when i purchase from them,could not beat that price on fox 2.0's anywhere as the going rate is aprox $130 ea.
