Tire size with no lift.
Cdills
I have a 2009 F350 with no lift. What is the largest tire I can get on the truck with no lift.
I'm going to lift it later on as I get the money saved to do it. At the moment I just want to put some bigger tires on it. What do you recomend? :rockon:
STROKIN N STYLE
GOM via NC
^^^ 35's fit. Mine rub at full lock. You can pull the inner fender back to prevent it
sent from somewhere in the country
rc4wd
The Rock, Ga
I've seen several sets of 35's and a couple sets o 325's around here with just a leveling kit.
madman1234509
mayfield, ny
I think ive seen one or two people stuff 37s under a stock truck. Im not really sure how it worked out or if it did at all. I personally wouldnt do it and think 35s look good with a stock truck and with a leveled.
Rene G
35x12.50 or 35x13.50 are the biggest I've run stock. The 13.50's rubbed a bit at full lock.
Rene G
I don't have any pics, it was on my old 05. If I run across any pics I'll post them.
clayton
FSJ, B.C Canada
I had 35x12.5 stock for a while, like others said.
Ive got a brand new set of n fabs for sale, bought wrong ones they're for ext cab. Im also in Canada...
