To WasteGate or Not to...
vr6nutt
SoCal
Just got some tunes (GH) for my recent build (38R, T500, AC Codes) Per suggestions, I've been running my 38R with the WG disabled and its been working fine thus far. Now that I am adding tunes, is it recommended that I re-enable the WG? Should I add a better actuator?
Dmstrucks02
Pearland, TX
Rod screwed all the way in, vac line capped. Red/green removed and capped as well.
I,never noticed a difference effing with the green and red lines. I guess you could check boost/ exhaust pressures and go from there. Shouldn't be an issue under normal driving
Justin@DP-Tuner
As stated, keep it tightened down and not functioning. AC codes are not going to hurt the 38R.
